Hi everybody,
I have a really strange issue with a theme I’m working on.
Here is the url of the blog : https://the-daily-test.ghost.io/ It’s in private mode, so here is the pass: zodese242
In the original theme, here: http://anima.pxt.be/ as you can see in the home page there is a “filter section”.
It was all ok since two days, all was running well. No problem on the filters.
Now, as you can see in my blog it’s not, there is no filters anymore.
Here is the solutions I tried to do:
Put the filter code directly in the defautl.hbs → didn’t work
Checked if a div wasn’t closed or something but all is ok.
Re-upload the original theme, to see if I did an error. But, even with the original code/theme, it didn’t show up anymore.
So I checked the code online, and in “view source”, the filter code disapeared. But in the ghost theme files, the code is here! When I upload the theme, this “filter code” is just erased…! I don’t know why, I’ve never seen that before!
What is really strange, is that two days before, all was ok.
If someone could help me it could be really cool!
Thanks in advance!!
