i’m sorry to be such a neophytye … is it possible for you to share how that’s done?
Paste this into your Site Footer Code injection:
<script src="https://code.jquery.com/jquery-3.6.3.min.js"></script>
If that doesn’t work, paste it instead into your Site Header Code Injection…
Please do report back here your results…
denvergeeks:
<script>
// For Dropdown Menu
(function($) {
"use strict";
function ghost_dropdown(options) {
let defultOptions = {
targetElement: "ul li",
hasChildrenClasses: "menu-item-has-children",
hasChildrenIcon: "<svg xmlns='http://www.w3.org/2000/svg' width='11' height='7' fill='currentColor' class='bi bi-caret-down' viewBox='0 0 11 7'><path d='M5.4999 6.20003L0.649902 1.35003L1.3499 0.650024L5.4999 4.80002L9.6499 0.650024L10.3499 1.35003L5.4999 6.20003Z'/></svg>",
hasChildDetectText: "[has_child]",
submenuUlClasses: "ghost-submenu",
subitemDetectText: "[subitem]",
subitemLiClasses: "subitem"
options = {
...defultOptions,
...options
console.log(options);
// Target Element
let targetElement = options.targetElement;
//Default value
let hasChildrenClasses = options.hasChildrenClasses;
let hasChildrenIcon = options.hasChildrenIcon;
let hasChildDetectText = options.hasChildDetectText;
let submenuUlClasses = options.submenuUlClasses;
let subitemDetectText = options.subitemDetectText;
let subitemLiClasses = options.subitemLiClasses;
// Declare neccesary variable
let parentEl = $(targetElement);
let childEL = $(targetElement);
let parentLen = 0;
let domArrayElement = [];
let indexPush = [];
let elIndex = 0;
let parentIndex = [];
$(`${targetElement}`).parent().addClass('ghost-dropdown-menu');
// Find Dropdown parent element
parentEl.each(function(index, element) {
if ($(this).text().indexOf(hasChildDetectText) >= 0) {
parentIndex.push(index); // Make dropdown parent array index
parentLen++;
$(this).push(element);
$(this).addClass(hasChildrenClasses); // Add class in dropdown element
$(this).append(`<ul class='${submenuUlClasses}'></ul>`); // Append submenu element
$(targetElement).css("opacity", "1");
$(`.${hasChildrenClasses}`).append(hasChildrenIcon);
// Using loop to reach dropdown parent element
for (let i = 0; i < parentLen; i++) {
elIndex = 0 // Initial element value
// Find subitem element
childEL.each(function(index, element) {
let subitem = $(this).text().includes(subitemDetectText); // Find subitem element
if (subitem) {
if (elIndex >= parentIndex[i + 1]) { // Each loop will be break
return false; //Stoped each loop
if (elIndex <= parentIndex[i + 1] || elIndex >= parentIndex[parentIndex.length - 1]) {
if (!indexPush.includes(index)) { //Check if not index already insert
$(this).addClass(subitemLiClasses); // Add class in subitem element
let st = $(this).children().text(); // Find subitem inner text
$(this).children().text(st.replaceAll(subitemDetectText, "")); // Replace subitem inner text
domArrayElement.push(element); // Incert subitem element in dom array
indexPush.push(index); // incert subitem index in indexPush array
elIndex++; // increase element index value
$(`.${hasChildrenClasses} ul.${submenuUlClasses}:eq(${i})`).append(domArrayElement); // Append related subitem dom element into submenu
// console.log(domArrayElement);
domArrayElement = []; // Make dom array element empty.
const hasChildEl = $(`.${hasChildrenClasses}`);
hasChildEl.each(function() {
if ($(this).find("> a:first").text().includes(hasChildDetectText)) {
console.log($(this).find("> a").text());
let hasChildText = $(this).find("> a:first").text(); // Find has child inner text
$(this).find("> a:first").text(hasChildText.replaceAll(hasChildDetectText, ""));
$(document).ready(function() {
ghost_dropdown();
}(jQuery));
</script>
Hi! It loads now, but I get a moment of it showing the links as X [has_child] X [subitem] before it shows the dropdown … is there a fix to this loading issue?
The problem is that the code runs late in the page load. Including it in the .hbs file (and avoiding jQuery) helps a LOT but then it’s no longer a code injection solution.
I see. Actually, I posted it to the main site from my test and it stopped working at all… hmmph.
I’m curious if you have an opinion
Please nvm if that is too much fuss.
@Tada_Hozumi You could try this one which loads smoothly and without that flash
OK @Joan I’ve got a new rendition of the script for the footer injection. I’ve also edited and commented a little more in the CSS.
For the script I just followed the example of the new overflow click-down menu in Casper. (The code you linked to at Added navbar options (#906) · TryGhost/Casper@cf30ada · GitHub )
Here’s what I’ve got now that’s working correctly. (This code might have extra cruft that can be removed. Hopefully someone better at JS can tell us.)
The CSS for the Site Header Code …
ah thank you, gonna try that out
tysm for your generous help @denvergeeks .
I was wondering, for the selectors in Edition:
I am assuming this is wrong but I can’t seem to find the right two selectors.
