Allow_promotion_codes
Using the Nio theme with a custom domain
Ghost Version: 6.10.2-0-gba885003+moya
Just wondering if someone can tell me how to get “allow_promotion_codes” going. I suspect it’s not as simple as doing a code injection, but hopefully it’s not terribly complicated. Or, if it IS somewhat complicated, is there someone I can hire to bang it out for me.
Thank you!
I believe that’s in a private beta. If you email support, they should be able to turn it on for you.
Fantastic. Thank you!
