Bad Gateway with Tinybird
And
    • Through a Dockerfile
    • Node version 22, MySQL db, ghost docker image and microsoft edge
    • Run the dockerfile alongside the container
Hello all,
I have a custom Ghost setup under a dockerfile with Caddy for activitypub, on flyio. I tried to set up tinybird by doing the following:
  1. Running docker compose on my machine and getting api, admin, relevant keys for tinybird
  2. Adding it to my ghost install
  3. Creating a new flyio app with traffic analytics image
  4. Using internal routing under caddy to route to the traffic analytics app
Whenever I open the site, I get a message saying 502 Bad Gateway under console. I believe it should be reachable by ghost, but not too sure since it is possible fly’s internal routing is ipv6 only, and the log shows its listening on ipv4 addresses
I would be happy to share any other information, like the fly config file. Environment variables wise, i kept it to be the same as the one found in docker compose. Thank you!
Log
2025-11-01T12:02:44.238 app[e28630d4ce4758] dfw [info] {"level":30,"timestamp":{"seconds":1761998564,"nanos":203000000},"pid":649,"hostname":"e28630d4ce4758","message":"Server listening at http://127.0.0.1:3000"}
2025-11-01T12:02:44.238 app[e28630d4ce4758] dfw [info] {"level":30,"timestamp":{"seconds":1761998564,"nanos":203000000},"pid":649,"hostname":"e28630d4ce4758","message":"Server listening at http://172.19.28.10:3000"}
2025-11-01T12:02:44.238 app[e28630d4ce4758] dfw [info] {"level":30,"timestamp":{"seconds":1761998564,"nanos":203000000},"pid":649,"hostname":"e28630d4ce4758","message":"Server listening at http://172.19.28.11:3000"}
Dockerfile
FROM caddy:2 AS caddy
FROM ghost:6
COPY --from=caddy /usr/bin/caddy /usr/bin/caddy
COPY ./Caddyfile /etc/caddy/Caddyfile
COPY ./snippets/ /etc/caddy/snippets/
RUN set -eux; \
    apt-get update; \
    apt-get install -y --no-install-recommends supervisor; \
    rm -rf /var/lib/apt/lists/*
COPY ./supervisord.conf /etc/supervisor/conf.d/supervisord.conf
EXPOSE 8080
CMD ["/usr/bin/supervisord","-c","/etc/supervisor/conf.d/supervisord.conf"]
Caddyfile
# Proxy analytics requests with any prefix (e.g. /.ghost/analytics/ or /blog/.ghost/analytics/)
@analytics_paths path_regexp analytics_match ^(.*)/\.ghost/analytics(.*)$
handle @analytics_paths {
	rewrite * {re.analytics_match.2}
	reverse_proxy ghost-tb-1.internal:3000
I have fixed this by editing the tinybird server to support IPv6 connections, TrafficAnalytics/server.ts at main · TryGhost/TrafficAnalytics · GitHub this file specifically, from 0.0.0.0 to ::
