Can we make {{ghost_head}} not create inline scripts?
Currently it’s impossible to turn off ‘unsafe-inline’ in your Content-Security-Policy header, since ghost_head outputs an inline script tag. Hence, it’s impossible to achieve the highest grade on https://securityheaders.com/ for instance…
The script that’s currently output by {{ghost_head}} is for initialising the v0.1 api - which has been deprecated, as far as I know in Ghost v3 we will remove it completely :tada:
However, if you’re not using the v0.1 api - you should be able to switch it off in labs, and the script will be removed :relaxed:
@naz Might be able to confirm this?
@osirisguitar which script exactly is preventing from turning off unsafe-inline? But assuming @egg is right about the script injected by API v0.1, moving to API v2 or disabling API v0.1 should remove it and the problem will be solved :slight_smile:
Turned off the old API in labs and the script tag is gone. Thanks for your help!
Turned off ‘unsafe-inline’ and got an A+ on my header report card now :-D
