Hello, I’m trying to change the color of tags in the post cards based on the color set for each tag. According to this article there’s a tag property called accent_color but I don’t know how to refer to that property in CSS? Can anyone help? Thanks!
You can’t refer to it from css, but you could do something like this in hbs:
{{#foreach tags limit="3"}}
<a class="post-card-tag tag-{{slug}}" href="{{url}}" {{#if accent_color}} style="--color-accent: {{accent_color}}"{{/if}}>{{name}}</a>
{{/foreach}}
You have the --color-accent CSS custom property which can be used in CSS.
.post-card-tag {
background-color: var(--color-accent);
That works thank you!
