Hi All, I am using source theme for my project and under that I used Magazine theme to activate and it showes theme activatd successfully but now showing online. I checked in incognito mode too.
Let me know how to make it possible.
Thanks in advance
Thanks in advance
Head over to /ghost > settings (gear icon in lower left > design and branding (click customize) > theme (tab on right side) - you’ve got theme config settings there and probably just need to change a few.
Hi Cathy, Thanks for yoru quick response.
I am doing from here but not sure what to change next. It is still showing the main theme of source not the child magazine theme which I want to use.
Did you follow the steps I gave above? It doesn’t work the way you’re trying to make it work, but the steps above will fix it.
Thank You Cathy, It worked. One more gneric question why I am not able to send invites to my team mmbers and nor able to access admin on other devices/browsers. Its working only in one browser on which i created account.
I am sorry for silly questions as I am new to ghost and wanted to swtich from Wordpress.
Once again thanks from bottom of my heart for your guidance and support.
You’re going to need to share some info about how you’re set up. Are you self hosting or in managed hosting? Some hosts provide limited staff member slots. Or you might need to get your transactional email configured,if self hosting .
Dear Cathy, I am using Self Hosting (DigitalOcean). After successfull installation on server. I created admin account using gmail. Now I have configured mailgun too but still no success, also I am not able to access admin on other devices/browsers. Its working only in one browser on which i created admin account.
I’m guessing your config.production.json does not have email configured, or else digital ocean is blocking the port you’re using.
