If you’re looking for help, please provide information about your environment. If you delete this template and don’t provide any information, your topic will be closed.
If you aren’t running the latest version of Ghost, the first thing we will ask you to do is update to the latest version of Ghost.
- What’s your URL? www.sambeckbessinger.com
- What version of Ghost are you using? Ghost Pro (locally, I’m on 4.3.3, and Ghost-CLI 1.16.3 - but that’s not where I’m running into issues)
And
- How was Ghost installed and configured? I am using Ghost Pro
- What Node version, database, OS & browser are you using? n/a
- What errors or information do you see in the console? n/a
Hi gang! I’m using Ghost Pro. I initially had two websites:
- likeafuckinggrownup.com, my ghost(pro) site
- sambeckbessinger.com, a static site run off Netlify
In both cases, I’m using Netlify to manage my DNS.
I decided to consolidate on sambeckbessinger.com. I’ve changed the Ghost(Pro) custom domain and sambeckbessinger.com is working great. But there’s a big 404 error on likeafuckinggrownup.com.
I’d like to set up 301 redirects to send all likeafuckinggrownup.com traffic to sambeckbessinger.com. I have NO idea how to do that - the redirects.yaml file only seems to redirect internally on the same base domain.
Does anyone know what I should be doing to fix this? Thanks so much for your help!
