I just followed the installation instructions for Ubuntu 18.04, all went fine but whenever I try to access my blog thought the URL I get Error 521, so server down. If I use my IP then I get the “Welcome to nginx” default page, I ran ghost doctor but I get no errors, talked to my hosting provider and told me that the DNS config was fine. So I’m not sure where to take it from here, any ideas?
my ghost config:
"url": "https://myurl.com",
"server": {
"port": 2368,
"host": "localhost"
"privacy": {
"useTinfoil": true
"database": {
"client": "mysql",
"connection": {
"host": "localhost",
"user": "user",
"password": "pass",
"database": "ghost_prod"
"mail": {
"transport": "Direct"
"logging": {
"transports": [
"file",
"stdout"
"process": "systemd",
"paths": {
"contentPath": "/var/www/ghost/content"
"bootstrap-socket": {
"port": 8000,
"host": "localhost"
and nginx
server {
listen 80;
listen [::]:80;
server_name myurl.com;
root /var/www/ghost/system/nginx-root; # Used for acme.sh SSL verification (https://acme.sh)
location / {
proxy_pass http://localhost:2368;
location ~ /.well-known {
allow all;
client_max_body_size 50m;
hosts file
127.0.0.1 localhost
127.0.1.1 my.myurl.com
# The following lines are desirable for IPv6 capable hosts
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
nginx status
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2019-06-09 11:46:51 PDT; 13s ago
Docs: man:nginx(8)
Process: 1128 ExecStop=/sbin/start-stop-daemon --quiet --stop --retry QUIT/5 --pidfile /run/nginx.pid (code=exited, status=
Process: 1130 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 1129 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 1131 (nginx)
Tasks: 2 (limit: 525)
CGroup: /system.slice/nginx.service
├─1131 nginx: master process /usr/sbin/nginx -g daemon on; master_process on;
└─1133 nginx: worker process
ghost doctor
$ ghost doctor
✔ Checking logged in user
✔ Checking operating system compatibility
+ sudo systemctl is-active ghost_myurl_com
Instance is currently running
ℹ Validating config [skipped]
✔ Checking folder permissions
✔ Checking file permissions
