Filter tags containing more than 5 posts
Hello Ghosts
I have a “tags” page where I want to see the main tags :
          {{#get 'tags' limit='all' include='count.posts' order='count.posts desc'}}
                {{#foreach tags visibility="public"}}
                    {{> "tag-card"}}
                {{/foreach}}
            {{/get}}
I would like to display only tags containing more than 5 posts. Is it possible?
By the way, the post count is global. If a tag contains 10 “member only” posts and 1 public, a non-member will see 11 posts and only one will show up when he goes to the tag page.
I understand that “get tags” function cannot do that?
Thanks
I don’t think you can do it with get directly.
But you can use a simple CSS trick:
In your tag card add a CSS class tag-card-count-{{count.posts}}
Then in your CSS use :
        .tag-card-count-0,
        .tag-card-count-1,
        .tag-card-count-2,
        .tag-card-count-3,
        .tag-card-count-4 {
            display: none;
Thanks, it’s a nice workaround, I will implement that!
Now that I think about it, you can also use the match helper
        {{#match count.posts ">=" 5}}
            {{> "tag-card"}}
        {{/match}}
    {{/foreach}}
{{/get}}
Perfect, it works!
https://blog.iero.org/tags/
Thanks a lot
