- What’s your URL? This is the easiest way for others to help you
- Nothing yet as I am still configuring
- What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
- N/A as trying to install from ghost-cli
And
- installation essentially doesn’t complete since it fails on the symlink creation step, and then the VM I am hosting it on becomes unaccessible via ssh
Node: 18
Database: MySQL (just install via ubuntu instructions on the ghost website)
OS: Ubuntu 20.04 hosted in a VM instance on GCP (e2-micro)
- No errors just hanging and it not finishing, then the VM instance becomes inaccessible via SSH afterward.
- npm issues:
- npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
- npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
Console output:
Provision a e2-micro instance using ubuntu 20.04 on GCP and follow the instructions on the ghost.org website for self hosting with Ubuntu in production.
