Error Id: bf044e30-ce40-11e9-835c-6bba3963180e
Error : 500
So It’s Like This I’m A Newbie Who’s Search For Tutorials On How To Install Ghost And After I Did All The Installations, My Website/Localhost Says : “500 Error Casper Something Is Not There (Then Directory Locations)”
(I Put Something Is Not There Because I Don’t Remember But I Do Remember The Error Code)
Please Help
Additional Information:
Using LTS Version Of Node.js
I don’t suppose you could give use a little more information? It’s a little hard to decipher what’s happening from the info you’ve given
I Did Do This Installations Many Times Because It’s Saying knex-migrator
is not installed.
and i run the command line “npm install -g knex-migrator”
cause i thought knex is not installed.
BTW I’m Using Node.js 10.13 LTS Version
And The Tutorial I Followed Said To Use Node.js LTS Version.
Is this a local or hosted version of Ghost? And just to check, is this a fresh install or an update?
Fresh Install And Locally
Ah ok, which tutorial are you following?
Youtube Tutorial Wait i’LL Get The Link
Ah I see, you’re best off following the official documentation. Here’s a link:
K Let Me Try.
Actually I’m Not A Coder Type Of Person. Just Following Tutorials
@DavidDarnes Yeah Suppose I’ll Use This Tutorial And Also That Tutorial That I’m Following Are Much More Difficult.
I’m afraid the video tutorial you were using is quite out of date
Yeah… Thanks For Suggestion.
