Ghost Meta Title Limit Removal
I’ve been trying to remove the Ghost meta title limit for 2 days now, I really cannot find a way to do so, I edited all the files with the “meta_title” and “title” with value from 300 to 2000, but still Ghost tells me that there is the limit of 300 characters. I checked and edited all these files:
/home/ghosthistory/history/content/data/history.ghost.2023-02-22-22-17-22.json
/home/ghosthistory/history/content/themes/dashi/default.hbs
/home/ghosthistory/history/versions/5.35.1/content/themes/casper/default.hbs
/home/ghosthistory/history/versions/5.35.1/content/themes/casper/error.hbs
/home/ghosthistory/history/versions/5.35.1/core/frontend/apps/amp/lib/views/amp.hbs
/home/ghosthistory/history/versions/5.35.1/core/frontend/helpers/meta_title.js
/home/ghosthistory/history/versions/5.35.1/core/frontend/meta/description.js
/home/ghosthistory/history/versions/5.35.1/core/frontend/meta/index.js
/home/ghosthistory/history/versions/5.35.1/core/frontend/meta/title.js
/home/ghosthistory/history/versions/5.35.1/core/server/api/endpoints/utils/serializers/input/settings.js
/home/ghosthistory/history/versions/5.35.1/core/server/api/endpoints/utils/serializers/input/utils/settings-key-group-mapper.js
/home/ghosthistory/history/versions/5.35.1/core/server/api/endpoints/utils/serializers/input/utils/settings-key-type-mapper.js
/home/ghosthistory/history/versions/5.35.1/core/server/api/endpoints/utils/serializers/output/utils/clean.js
/home/ghosthistory/history/versions/5.35.1/core/server/data/schema/schema.js
/home/ghosthistory/history/versions/5.35.1/core/server/data/schema/default-settings/default-settings.json
/home/ghosthistory/history/versions/5.35.1/core/server/data/schema/fixtures/fixtures.json
/home/ghosthistory/history/versions/5.35.1/core/server/services/url/config.js
/home/ghosthistory/history/versions/5.35.1/core/shared/settings-cache/public.js
/home/ghosthistory/history/versions/5.35.1/node_modules/@tryghost/admin-api-schema/lib/schemas/pages.json
/home/ghosthistory/history/versions/5.35.1/node_modules/@tryghost/admin-api-schema/lib/schemas/posts.json
/home/ghosthistory/history/versions/5.35.1/node_modules/@tryghost/admin-api-schema/lib/schemas/tags.json
/home/ghosthistory/history/versions/5.35.1/node_modules/@tryghost/mongo-knex/test/integration/relations.test.js
/home/ghosthistory/history/versions/5.35.1/node_modules/@tryghost/mongo-knex/test/integration/suite1/schema.js
/home/ghosthistory/history/versions/5.35.1/node_modules/@tryghost/mongo-knex/test/integration/suite1/fixtures/base.json
/home/ghosthistory/history/versions/5.35.1/node_modules/@tryghost/mongo-knex/test/unit/convertor.test.js
/home/ghosthistory/history/versions/5.35.1/node_modules/gscan/lib/faker/index.js
/home/ghosthistory/history/versions/5.35.1/node_modules/gscan/lib/specs/canary.js
/home/ghosthistory/history/versions/5.35.1/node_modules/gscan/lib/specs/v1.js
/home/ghosthistory/history/versions/5.35.1/node_modules/gscan/lib/specs/v2.js
