I’m running mac, bought a theme from gbjsolution.com from themeforest
I open the navigation.hbs file in text editor on my mac and change it to PHOENIX Capital Blog for the A href but it doesn’t save…
It says node.js i have to do something with i have no clue what to even do…never done this before…
<li class="nav-item member-link" role="menuitem"><a href="{{@site.url}}/subscribe/" class="btn-primary">{{t "Subscribe"}}</a></li>```
i just need it to open https://www.phoenixcapitalblog.com/#/portal
That is literally all I need... if someone can PM me and help me with that and bless me that be great cuz i have no clue how to do node.js or any of that...
You don’t usually need to add login etc. to the menu. Use the membership settings, and check your theme instructions, since some require changes to routes.yaml.
