I urgently need to deactivate portal.-
First of all, I think I personally must congratulate you on the extraordinary job you are doing with the product. But I think the differentiating goal of Ghost is deviating: Simplicity.
I think it should be possible to activate the members, outside the popup - portal system itself.
Well, within the system itself it includes many disadvantages:
The use of CDN (Cloudflare) decreases the loading speed and the organic positioning. The file service must be integrated locally, never on the CDN.
The use of Popups, goes against the recommendations of use of the Core Web Vitals, therefore it negatively affects the SEO.
In the same way, although the Ghost product is very well structured and executed, the use of JS on the client side also decreases the functionality on various devices.
Multiple insertions of CSS layers create unnecessary elements, which should be optimized correctly, and serve in just one.
In addition, an indiscriminate number of active URLs are included, that even if I remove the button and do not use them, they remain active, losing part of my budget crawler and generating unnecessary confusion.
http://localhost:2368/#/portal
http://localhost:2368/#/portal/signin
http://localhost:2368/#/portal/signup
Please @John, @DavidDarnes, @rishabhgarg, @minimaluminium, Ghost team … we need to rethink the proposed system to be able to work at different levels, for those who want an “easy to incorporate” functionality and more optimized options for those who want to take Ghost to the next level.
I await an answer from you, because I deeply believe in this project. I believe without any doubt that the future of web development goes through Ghost.
I await your response,
Thanks for your time and interest,
A hug.
Jesus PĂ©rez.-
