I want to define a string in global variable, such as “slug:[xx0,xx1]”.
because I want to reuse it in different pages. and it can be more maintainable.
sorry for my English
This isn’t really possible, but you can kind of hack a couple of global variables by repurposing other fields.
For example, create a an author called data
- you can now use the get helper, wherever you want to access that variable, which can be updated via admin.
eg. here I’ve used the author.location field to store a custom string:
{{#get "authors" filter="slug:data" as |data|}}
{{#foreach data}}
{{location}}
{{/foreach}}
{{/get}}
