How to Add ElevenLabs Audio to Every Ghost Post
I wanted one simple thing:
Every Ghost post should have a “Listen” button.
I did not want to paste ElevenLabs code into every post manually.
The solution was much simpler:
Set up ElevenLabs Audio Native once, then add one script to Ghost Code Injection.
That’s it.
Here’s how.
1. Set up Audio Native in ElevenLabs
In ElevenLabs, open Audio Native.
Choose the voice you want.
Then add your Ghost domain under Allowed Sites.
Example:
https://yourblog.com
Then click Get Embed Code.
You’ll see something containing:
data-publicuserid="YOUR_ID_HERE"
Copy that long ID.
Do not use your ElevenLabs API key.
2. Test it on one Ghost post first
Open one post in Ghost.
Add an HTML card near the top of the article:
+ → HTML
Paste the ElevenLabs embed code into that HTML card.
Publish/update the post.
Open the live post.
You may initially see:
Converting the page to audio…
Give it a minute or two.
Then the ElevenLabs player should appear.
Press Play.
If it works, move on.
3. Add it to every post automatically
Now go to:
Ghost → Settings → Advanced → Code Injection → Site Footer
Paste this:
<style>
.elevenlabs-ghost-player {
width: 100%;
margin: 24px 0 32px;
</style>
<script>
(function () {
if (!document.body.classList.contains('post-template')) {
return;
if (document.getElementById('elevenlabs-audionative-widget')) {
return;
const content =
document.querySelector('.gh-content') ||
document.querySelector('.post-content') ||
document.querySelector('.article-content');
if (!content) return;
const wrapper = document.createElement('div');
wrapper.className = 'elevenlabs-ghost-player';
wrapper.innerHTML = `
<div
id="elevenlabs-audionative-widget"
data-height="90"
data-width="100%"
data-frameborder="no"
data-scrolling="no"
data-publicuserid="YOUR_PUBLIC_USER_ID"
data-playerurl="https://elevenlabs.io/player/index.html"
Loading audio...
</div>
content.insertBefore(wrapper, content.firstChild);
if (!document.querySelector('script[src*="audioNativeHelper.js"]')) {
const script = document.createElement('script');
script.src = 'https://elevenlabs.io/player/audioNativeHelper.js';
script.async = true;
document.body.appendChild(script);
</script>
Replace:
YOUR_PUBLIC_USER_ID
with the ID you copied from ElevenLabs.
Click Save.
4. You’re done
Now every Ghost post gets the ElevenLabs player automatically.
You do not need to:
edit every old post
add a new embed every time you publish
build an API
use GitHub
run your own server
The same Ghost Code Injection works for old posts and future posts.
One final tip: open your old posts once after installing this. That lets ElevenLabs generate the audio ahead of time, so readers don’t see the initial “Converting the page to audio…” message.
I tested this across 35 Ghost essays, and all 35 ended up with working audio.
That’s the whole setup.
