Is there some way - like bat file or smth that would automatically
cd to my ghost folder, then just run ghost start and open http://localhost:2368
all that just by me clicking on it?
I hate command prompt -.-
Well, You said you are lazy that’s why I have spent some time and manadged to make something working for you.
Add the following code in .bat file and save that file. double click that file.
I assume you have your ghost folder in C: driver. In case not. Change the second line C:\ghost
with your ghost folder path.
@ECHO off
CD /D C:\ghost
CMD /C "ghost start"
start /wait http://localhost:2368/
ECHO.
ECHO Do you want to restart or stop Ghost?
:choice
ECHO.
set /P c=[ enter R=restart / S=Stop ]?
if /I "%c%" EQU "R" goto :restart
if /I "%c%" EQU "S" goto :stop
goto :choice
:restart
CMD /C "ghost restart"
goto :choice
:stop
CMD /C "ghost stop"
exit
excellent! Thanks a lot.
may long live one click solutions
This should come with every installation. LOL
That’s bit crazy anyway I am glad that it helped you.
