Importing labels instructions incorrect
The ghost documentation says that importing labels should look like this
However if you import using that format, the import is two labels:
“label 1
label 2”
Not
label 1
label 2
as expected
Issue Summary
  • Explain roughly what’s wrong
  • What did you expect to happen?
Steps to Reproduce
  1. This is the first step…
  2. This is the second step, etc.
Setup information
Ghost Version
Share which version of Ghost you’re using.
Node.js Version
If self-hosting - share which version of Node.js you’re using.
How did you install Ghost?
Provide some details about your install of Ghost if you are self-hosting.
Include further details about your hosting and OS.
Database type
MySQL 5.7 / MySQL 8 / SQLite 3 / Other
Browser & OS version
Include if reporting frontend bugs.
Relevant log / error output
Copy and paste any relevant log output. Use backticks to format this into code.
Hey! Using the example temlpate in the help doc you linked to, I can’t reproduce this on Ghost 5.130.0.
email,name,note,subscribed_to_emails,stripe_customer_id,complimentary_plan,labels,created_at
testemail@example.com,Test Email,A note,true,,false,"Test 1, Test 2, Test 3",2019-10-30T14:52:08.000Z
Could you share a reduced test case and Ghost version?
