Mixed content warning
My website is https://discoverghost.com.
I change the URL to contain https and I’m getting a mixed content warning. To fix it do I need to update the custom theme and add https in front of the image URL set for logo, etc. ?
If you’re self hosted, you need to update the site url for your instance.
The best way to do this is run the following command in your installation directory: ghost config url https://discoverghost.com && ghost restart - this will update the URL and restart ghost.
If you’re using Ghost (Pro), you should email support.
You also have a couple of resources that have the scheme hardcoded, such as Google Fonts. You need to update that in your theme.
Hey Vikas,
Thanks for the quick reply. I ran the command you mentioned earlier after which I started getting the issues.
P.S. For my 2 other ghost sites, this went smoothly.
In that case, you probably have hardcoded schemes (like google fonts).
The assets I’m seeing not loading properly are:
  • Google Fonts
  • Mailchimp
  • Ad for stretch
These all seem to be from elements that are hardcoded in your theme - the next step is to make sure the scheme isn’t hardcoded there.
