Hello,
My site (https://ffplan.com) was upgraded to 5.0 and now the header logo is missing and none of the primary nav menus are visible. Before the upgrade, I ran the ghost Gscan tool and I only got two “yellow light” warnings (see below) which I did not fix.
There should be 7 primary nav links and a header image that aren’t showing.
Any suggestions would be helpful; I am a newbie, not a developer but I can make basic .txt file changes and repackage to .zip for upload if it’s that’s simple…
Warnings:
Remove "engines.ghost-api"
from package.json
The "ghost-api"
version is no longer used and can be removed.
Find more information about the package.json
file here.
"card_assets"
will now be included by default, including bookmark and gallery cards.
Hide details
The "card_assets"
property is enabled by default and set to true
(include all) if not explicitly set.
Find more information about the card_assets
property here.
