I just started using Ghost blog. What steps do I need to follow to solve these problems?
This error is saying that you need to include the .kg-bookmark-card
and .kg-bookmark-author
classes in your theme CSS files.
Thank you for your reply.
Could you give a little hint about this subject?
Do I need to use Visual Studio Code?
The Neon theme should work out of the box. I’d reach out to the theme developer to see what might be happening because you probably shouldn’t need to deal with that error in the first place.
Which version of Ghost are you on?
- Version: [5.33.6]
Awesome. I think the best solution will likely come from the theme developer: Support for Neon - Multipurpose Ghost Theme for Blog and Newsletter
I think this theme is faulty. Can I reset my site? I want to format it.
You can switch to a different theme by following the directions here:
