No schema with key or ref "http://json-schema.org/draft-07/schema#"
Installing Ghost locally
Downloaded source for ghost using Ghost-2.19.0.zip
To Reproduce
  1. unzip files to working_folder Ghost-2.19.0
  2. "npm install" followed by
  3. "npx knex-migrator init"
  4. finally "npm start"
  5. setup admin page
  6. http://localhost:2368/ghost
  7. edit post
    update show error Internal server error, cannot edit post. no schema with key or ref “http://json-schema.org/draft-07/schema#
Below Error Log is spit out in console
ERROR [2019-08-16 14:12:31] “PUT /ghost/api/v2/admin/posts/5d1edb018123bb128529b196/” 500 24ms
Error ID:
e30bfb80-c02f-11e9-b631-25f422ebe24d
Technical details:
Ghost Version: Ghost-2.19.0
Node Version:v8.10.0
Browser/OS:Firefox / Ubuntu
Database:
Have you tried following the official local install instructions? It may be useful to try those first so that there’s something to compare your custom install steps against (eg, using npm vs yarn could give you different dependency versions)
