Not updating translations – how to fix?
I have a Ghost installation running in a container on my VPS. I updated the translation files in
/var/lib/ghost/versions/5.109.2/node_modules/@tryghost/i18n/locales/,
deleted the old translations, and uploaded the new ones. However, Ghost still displays the old version of the translations. Restarting the container and running ghost buster didn’t help.
What do I need to do to force Ghost to load the new translations?
I’d really appreciate any help!
Which translations are you trying to update? E.g. Theme, portal, newsletter, etc. The folder you shared is minimally used on a production installation of Ghost.
I’m trying to update the translations for comments.json, ghost.json, newsletter.json, portal.json, search.json, and signup-form.json.
What’s the correct way to update the translations myself?
Here are the correct Polish translations: GitHub - MrLucas1991/ghost_pl_PL_i18n
Honstly, the simplest option is to contribute changes to the Ghost repo (Help translate Ghost (beta)). I say this because you’ll have to create a custom comments, portal, search, and signup-form build.
