Hi there!
Is there an easy way to order posts by clicks?
Hi there!
Hey there. That’s an interesting request. You’re going to need something that tracks analytics for each post, Google Analytics is normally the go-to. After that you could use the Analytics API to query which posts are being clicked the most and order them using JavaScript. There’s more info on the Google Analytics documentation:
Thanks, David! It sounds like the right path to follow. I’ll check it out later and post what I may find out
