I had imported data from my current WordPress website into Ghost and now that most settings and theme is setup, I want to delete all the posts and tags and import them again. Is the best way to do this, is to simply delete all the posts and tags and then re-import everything?
Also, when should I move the domain over? Based on @Cathy_Sarisky recommendation, my plan is:
- Import all the posts to my Ghost Pro temp domain
- Remove password protection
- Move the Domain over
Once that is done, add Google Analytics/GSC code and other scripts. A couple of questions with domain- once the domain is live, do I need to recreate any URLs such as menu items etc. that are currently pointing to the temp domain? Also, I just want www to redirect to domain.com so what would be the right record for that (Using cloudflare)
