Reorganize "add blocks" content
It will be great if we could reorganize this menu.
I use Gallery most of the time and I have to scroll quite often.
The clickable menu is there to get you started, once you’re familiar with the options available it’s much quicker to use the / menu where you can type /g and it will auto-filter to the galley then you can press the enter key to create one.
Cool, I did not know this shortcut!
Maybe you could add a [/g] in the clickable menu to help other people to learn the shortcuts?
Thanks @Kevin for the tip
