Hey @aslmabas The schema is generated in “meta” part of Ghost particularly in this module, in particular, ImageObject comes from:
In this particular case, it seems like a bug And my understanding is that logo value should be an object containing url property instead of just the url string as it is now. Would appreciate if you could file this as a bugreport in Ghost repo with steps to reproduce this issue ;)
There was an issue filed for this in the Ghost repo but there was not much traction from community to fix it. Would be great if somebody could step in to help with it ;)
Hey @Eric_Morgan! We have a 2 week release cycle with optional release in between if there’s enough features/fixes/ect to justify rolling one out There is a planned release next week - March 9-10ish
I see it’s closed but when I test the structured data on our ghost instance I still am getting the same error on the publisher logo:
We are using Ghost Pro and a custom theme based off Casper. I figured since this was a /core/ feature that is outside the theme that it would update the structured meta data automatically when the PR was merged to TryGhost:Master.
Hi @Eric_Morgan, your contribution has gone out as a part of 3.10.0 release and that was deployed on Pro environment the same week release was done. If you are experiencing this same issue on your Ghost(Pro) instance feel free to shoot an email to support@ghost.org and we’ll be more than happy to give you a hand directly!
