I’m hosting my ghost instance in a subdirectory /ghost, with nginx acting as a reverse proxy. I managed to get the location block in nginx working fairly quickly, and
example dot com/ghost
showed me the homepage for the blog with all the example posts. What I was not able to do, was navigate to the login at
example dot com/ghost/signin
, it just redirected me back to the base subdirectory and homepage.
I tried editing my
/var/www/ghost/config.production.json
to change the subdirectory thinking maybe example.com/ghost was somehow redirecting incorrectly, but this caused an error 502 bad gateway. I’ve since changed it back, but the 502 remains. All my other subdirectories work fine still. To clarify, I also adjust my nginx
example.conf
file with the same change and then reversion as the ghost c.p.json file.
So I guess I have two questions now, should I just wait and see if maybe cloudflare needs to update for the 502 error? And what do you make of my original redirecting to the home page problem?
