Hey There
I’m trying to set up rel attributes and open HTML links in a new tab. Whenever I create an HTML block within a post, the links come out with space around them. I haven’t found anything in the CSS.
If you look at the word “community,” the link has spacing after source and before the “.”
How do I fix this?
What’s the HTML code you’re using for the entire block?
Sorry, @Stromfeldt. Should have posted that…
The version of Ghost you are looking at right now would not have been made possible without generous contributions from the open source <a href="https://ghost.org/pricing/" rel="nofollow">community</a>.
Wrap your paragraph in <p></p> tags. HTML blocks don’t assume what your content will be and so don’t include any kind of opening or closing tags.
Worked. Thanks @Stromfeldt
