Not sure if this is the right forum but I would like to raise a bug report here.
I have recently set up my Ghost blog at zinkohlaing.com and it is self-hosted via Pikapods.
Here’s an example URL that contains the tag “OMSA”
I can see from Inspect Element that it should be redirected to https://www.zinkohlaing.com/tag/omsa/
But when I open this link or click on the tag, it is redirected to 404.
Based on my research, it seems that my Route file needs to be updated/changed. But the thing is I haven’t made any modifications since the setup.
I have already deleted / re-added the tags and it is happening to all tags so far, including the newly created tags.
Ghost Version
5.100.1
Raki
2
The tag page is being redirected to /tag/
, you need to check the routes and redirect config.
@Raki
Thanks for your reply.
Below is what they looked like.
Raki
5
The problem comes from your redirect settings. Any route containing’ oma,
gaming`, etc., will be redirected, so the tag page is redirected.
Thanks!
It’s because I used to have a Wordpress account that uses this type of URL:
zinkohlaing.com/omsa/{{sometext}}
I needed to remove /omsa/ and redirect them to correct URL in Ghost. Am I doing it wrong?
I have removed all redirects and it seems to work now
So the trick is to use regex notation to only match the first part… so your first one becomes:
^\/omsa\/(.*): /$1
That’s going to only match lines that start with /omsa/, instead of anything with /omsa/ in it.
system
Closed
9
