Issue Summary
When I create a new tag in the admin interface, the {{tags}} helper returns 404 as the {{url}} even though it’s setup in the admin interface correctly. This has been mentioned before here but not reported as a bug.
{{url}} to resolve to new tag url
Steps to Reproduce
Use {{tags}} helper in default.hbs
Add a new tag on the admin interface
Add that tag to a post
Load a page with {{tags}} in
Setup information
Ghost Version
5.128.0
Node.js Version
v20.19.3
How did you install Ghost?
python venv,
a nodeenv inside the venv,
use npm to install ghost-cli@latest
run ghost install local
Local development in WSL Ubuntu on Windows
Different issue. I just double-checked and I’m sure of it. This happens with a post in the tag. If it doesn’t happen for you, perhaps it’s something to do with ghost install local?
Any chance you’re updating tags using the bulk edit function from the list of posts, instead of on the individual posts? If so, that’s probably your problem. Ghost doesn’t update routing in response to bulk edit changes.
Hang on… I’m confused. Are you changing the slug of the tag from /ghost/#/tags? Or something else? Creating a new tag from /ghost/#/tags wouldn’t apply it to any posts, so I’m missing something here.. .
I right clicked on it in what you presumably call the bulk editor, but I didn’t know it did bulk editing when I added the tag so the penny has only just dropped.
Ahha! Mystery solved, then! So, to get immediate updates, click into the post and add the tag there, instead of from the list of posts.
(I’ve got a bug open on it.)
Update: I think as long as you add the tag to one post using the post editor (not bulk edit), everything should behave correctly. It’s just that the difference between 0 posts with a tag and 1+ post with a tag changes the routing, and ghost doesn’t realize there are any posts with that tag unless at least one of them gets it via the post editor.
