Theme settings disable functionality
Using the theme configuration, themes should be able to disable some ghost blog functionality.
Example:
An old theme that does not yet support new ghost versions should be able to disable things like image sizing, etc.
If a theme doesn’t support the available features in a version of Ghost then it’s not compatible with that version and you will get appropriate warnings/errors when installing it.
Old themes won’t know what future features will be available so it’s not possible for them to pre-emptively disable core Ghost features. Having core features enabled/disabled without the user’s consent also creates expectation, documentation, and support problems so it’s not something that would be implemented without serious consideration to knock-on effects.
