If you’re looking for help, please provide information about your environment. If you delete this template and don’t provide any information, your topic will be closed.
If you aren’t running the latest version of Ghost, the first thing we will ask you to do is update to the latest version of Ghost.
- What’s your URL? echointeractive.co.uk
- What version of Ghost are you using? latest
And
on the command line following the ubuntu 18.04 installation guide -
Node: latest, Database: mysql, OS: Ubuntu 18.04, Browser: Opera GX but also tested on chrome -
Aug 31 18:20:00 mail.echointeractive.co.uk node[69507]: at Object.getThemeValidationError (/var/www/****/versions/4.11.0/core/server/services/themes/val
Aug 31 18:20:00 mail.echointeractive.co.uk node[69507]: at Object.module.exports.loadAndActivate (/var/www/****/versions/4.11.0/core/server/services/the
Aug 31 18:20:00 mail.echointeractive.co.uk node[69507]: at async initFrontend (/var/www/****/versions/4.11.0/core/boot.js:122:5)
Aug 31 18:20:00 mail.echointeractive.co.uk node[69507]: at async bootGhost (/var/www/****/versions/4.11.0/core/boot.js:329:9)
Aug 31 18:20:01 mail.echointeractive.co.uk node[69507]: [2021-08-31 18:20:01] INFO Ghost booted in 3.806s
Aug 31 18:20:01 mail.echointeractive.co.uk node[69507]: [2021-08-31 18:20:01] INFO Adding offloaded job to the queue
Aug 31 18:20:01 mail.echointeractive.co.uk node[69507]: [2021-08-31 18:20:01] INFO Scheduling job update-check at 5 30 2 * * *. Next run on: Wed Sep 01 2021
Aug 31 18:20:01 mail.echointeractive.co.uk node[69507]: [2021-08-31 18:20:01] INFO Bootstrap client was closed.
Not really sure. It was working perfectly fine until I installed mattermost on the server on a different domain, then it was saying there was an SSL error, I reinstalled the certificates using certbot andthat fixed that, but now there’s an issue that it’s saying TOO MANY REDIRECTS and systemctl says it’s a ThemeValidationError
