I want to update to Ghost 5.0
Unfortunately I’m a new user and maximum of 3 links is allowed. I’m making links Googlable
What’s your URL?
Staging: https://blog.hexs.io (Where I am having the problem at the moment)
Production: Link: Blog Colonist -
Ghost-CLI version: 1.11.0
I think Ghost 2.x -
Was using the latest version in Digital Ocean marketplace: Ghost | DigitalOcean Marketplace 1-Click App -
NPM: 6.4.1
Node: v10.13.0 -
I had some problems with updating this. It asked me to update node, then asked npm update, I messed around with those versions now I am stuck here:
ghost-mgr@ghost-staging:/var/www/ghost$ ghost help
/home/ghost-mgr/.nvm/versions/node/v10.13.0/lib/node_modules/ghost-cli/node_modules/yargs-parser/build/index.cjs:1015
throw Error(`yargs parser supports a minimum Node.js version of ${minNodeVersion}. Read our version support policy: Link: Github /yargs/yargs-parser#supported-nodejs-versions`);
Error: yargs parser supports a minimum Node.js version of 12. Read our version support policy: Link: Github /yargs/yargs-parser#supported-nodejs-versions
at Object.<anonymous> (/home/ghost-mgr/.nvm/versions/node/v10.13.0/lib/node_modules/ghost-cli/node_modules/yargs-parser/build/index.cjs:1015:15)
at Module._compile (internal/modules/cjs/loader.js:688:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:699:10)
at Module.load (internal/modules/cjs/loader.js:598:32)
at tryModuleLoad (internal/modules/cjs/loader.js:537:12)
at Function.Module._load (internal/modules/cjs/loader.js:529:3)
at Module.require (internal/modules/cjs/loader.js:636:17)
at require (internal/modules/cjs/helpers.js:20:18)
at Object.<anonymous> (/home/ghost-mgr/.nvm/versions/node/v10.13.0/lib/node_modules/ghost-cli/node_modules/yargs/build/index.cjs:1:59993)
I’m honestly not sure.
I’m running these in the staging version at the moment. I ultimately want to be able to update ghost blog into a new version. Here are some links I’ve looked at:
Link: Ghost Reinstall
Link: Ghost CLI
setupmy.life/update-ghost/#:~:text=To%20update%20Ghost%20Manager%2C%20use,g%20ghost%2Dcli%40latest%20.&text=After%20the%20successful%20update%2C%20you,and%20you%20are%20all%20done
Alternatively I’m thinking of exporting everything and reimporting the whole blog. But it seems it doesn’t export the images. I could use a simpler solution like that if someone points me into the right direction about the images.
Link: Ghost the Importer
