Using A Channel To Filter Out Tags On Homepage -> RSS
I am currently using
routes:
    controller: channel
    filter: tag:-[how-to,about,under-the-hood]
This works perfectly as I was looking at a way to filter out certain tags from the homepage, however, this method seems to remove the posts from the main /rss feed which I could do without.
Is there a way for it not to do this or is the only solution going to have to be to create a custom RSS feed?
I tried the {{#get “posts” filter="tag-:tag1… route but that breaks pagination on the homepage.
Interesting - can you share your whole routes file?
Will do. Just to clarify it’s only the posts with tags that I have excluded that no longer show up on the feed.
This is the current routes file:
routes:
    controller: channel
    filter: tag:-[news]
  /sitemap/:
      template: sitemap
      content_type: text/xml
  /news/rss/:
    template: news/rss
collections:
      permalink: /{slug}/
      template: index
taxonomies:
  tag: /index/{slug}/
  author: /author/{slug}/
/news/rss/ is a custom RSS and it looks like we will need to use this as the master going forward as using a channel removes the entries from the main homepage feed (-news)
/sitemap/ is a custom Google news feed.
OK, I think have decided to just take the custom RSS route.
Thanks.
