It does something allright but I can’t seem to be able to find any information on this in the documentation and too lazy to read code :)
There’s no ghost setup instance
command
$ ghost setup --help
ghost setup [stages..]
stages can be one or more of nginx, ssl, mysql, systemd, migrate, linux-user
According to the documentation there is not yes. But you would be surprised to see that there actually is if you run it :)
It does something but no idea what.
Oh, that’s an internal step It adds the instance to the list of installed instances (
ghost ls
), and makes sure that the content path is configured in the config file.
Edit: these internal steps aren’t designed to be run independently
