Using Bitnami, Azure B1S package is not listed. I choose this package because it’s free. So, could someone help me how to install Ghost in Azure on B1S package?
That’s because you don’t have Ghost installed in that directory.
You need to create installation directory… like /var/www/ghost and set proper permissions, do ghost install then you won’t get this error.
This is additional info from me. After run ghost version, here the result:
secret@serverme:~$ ghost version
Ghost-CLI version: 1.9.8
secret@serverme:~$
Then, I run dpkg -l, this is the result:
ii fuse 2.9.4-1ubuntu3.1 amd64 Filesystem in Userspace
ii gawk 1:4.1.3+dfsg-0.1 amd64 GNU awk, a pattern scanning and processing language
ii gcc-5-base:amd64 5.4.0-6ubuntu1~16 amd64 GCC, the GNU Compiler Collection (base package)
ii gcc-6-base:amd64 6.0.1-0ubuntu1 amd64 GCC, the GNU Compiler Collection (base package)
ii gdisk 1.0.1-1build1 amd64 GPT fdisk text-mode partitioning tool
ii geoip-database 20160408-1 all IP lookup command line tools that use the GeoIP library
ii gettext-base 0.19.7-2ubuntu3.1 amd64 GNU Internationalization utilities for the base system
ii gir1.2-glib-2.0:amd64 1.46.0-3ubuntu1 amd64 Introspection data for GLib, GObject, Gio and GModule
ii git 1:2.7.4-0ubuntu1. amd64 fast, scalable, distributed revision control system
ii git-man 1:2.7.4-0ubuntu1. all fast, scalable, distributed revision control system (ma
ii gnupg 1.4.20-1ubuntu3.3 amd64 GNU privacy guard - a free PGP replacement
ii gpgv 1.4.20-1ubuntu3.3 amd64 GNU privacy guard - signature verification tool
ii grep 2.25-1~16.04.1 amd64 GNU grep, egrep and fgrep
ii groff-base 1.22.3-7 amd64 GNU troff text-formatting system (base system component
ii grub-common 2.02~beta2-36ubun amd64 GRand Unified Bootloader (common files)
ii grub-gfxpayload-lists 0.7 amd64 GRUB gfxpayload blacklist
ii grub-pc 2.02~beta2-36ubun amd64 GRand Unified Bootloader, version 2 (PC/BIOS version)
ii grub-pc-bin 2.02~beta2-36ubun amd64 GRand Unified Bootloader, version 2 (PC/BIOS binaries)
ii grub2-common 2.02~beta2-36ubun amd64 GRand Unified Bootloader (common files for version 2)
ii gzip 1.6-4ubuntu1 amd64 GNU compression utilities
ii hdparm 9.48+ds-1ubuntu0. amd64 tune hard disk parameters for high performance
