Writter theme not working
Hey,
Very new to this and was just playing with the 14 day trial today. I downloaded the Writter theme and got this message back:
Any pointers as to what to do next? I have no clue how to fix the errors so is there an easy route?
Cheers
Steve
Full documentation on upgrading around breaking changes are here:
You’re looking at a theme dependent on the v0.1 API. If it’s a premium theme you should contact them and ask them to upgrade the theme.
If you’re looking to do this yourself you’ll need to figure out what’s using the ghost.url.api() helper in the file assets/js/main.js and either rip it out or replace it with code that uses the newer client libraries.
