Zapier integration SSL failure
I’m getting an odd SSL error that might be related to TLS versioning based on searching up select bits of the error. Here it is below, in its unformatted glory:
authentication failed: request to https://jmk.sh/ghost/api/v2/admin/site/ failed, reason: write EPROTO 140623696443200:error:1409442E:SSL routines:ssl3_read_bytes:tlsv1 alert protocol version:…/deps/openssl/openssl/ssl/record/rec_layer_s3.c:1544:SSL alert number 70
My blog is “private” right now but I had that setting off while attempting to set this up. The rest of the actions in the Zap work without issue.
Filed tickets with Zapier and DigitalOcean. Found that it’s the DigitalOcean Droplet requiring TLS 1.2 for now; if anyone is using TLS 1.3 across their entire stack with Zapier successfully I (and Zapier support) would love to hear from you!
