Hi ![]()
I have just updated my NPM version from npm 6 to 7 on my ghost installation.
The version I’m running now is: 7.17.0
I have used this command “sudo npm install -g npm@latest” to update NPM
But now if I running the command to update ghost-cli with this command: “sudo npm install -g ghost-cli@latest”
I get this warning:
changed 419 packages, and audited 420 packages in 11s
29 packages are looking for funding
runnpm fundfor details5 high severity vulnerabilities
To address all issues (including breaking changes), run:
npm audit fix --forceRun
npm auditfor details.
The command “npm audit fix --force” doesn’t fix the warning!
Will I have to be worried about the warning? and what did it mean?
EDIT-1:
If I’m running this command: “npm audit” I’m getting this output
found 0 vulnerabilities
EDIT-2:
Ghost-CLI version: 1.17.3
Ghost version: 4.7.0 (at /var/www/ghost)
Node version: v14.17.0
Site: https://www.futurenode.dk
Thanks
Thomas
