[Solved the original issue. See my reply for the continuing saga of the 502 bad gateway]
Hi - I’ve been trying to clean up what was once a multi-site hosting of ghost and is now only a site site hosting. I’m very nearly there, I think as I’ve fixed a whole heap of symlink issues and mysql problems. But I’m still getting a 502 Bad Gateway message which I’m fairly sure is some kind of permissions issue. Here’s the output from “ghost doctor”:
Checking system Node.js version
Checking logged in user
Ensuring user is not logged in as ghost user
Checking if logged in user is directory owner
System checks failed with message: ‘Linux version is not Ubuntu 16, 18, or 20’
For local installs we recommend using ghost install local instead.
? Continue anyway? Yes [Note, system is Raspberry Pi"]
System stack check skipped
Checking system compatibility [skipped]
Checking for a MySQL installation
- sudo systemctl is-active ghost_corballis-co-uk
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
Checking binary dependencies
Checking free space
One or more errors occurred.
- undefined
Error: EACCES: permission denied, open ‘/var/www/corballis.co.uk/.ghost-cli’
OS: Raspbian GNU/Linux, v9
Node Version: v14.15.3
Ghost Version: 3.40.2
Ghost-CLI Version: 1.15.3
Environment: production
Command: ‘ghost doctor’
