I’m pretty sure this is a bug, cause partial param is printed correctly outside {{#get}} helper, but not inside.
Issue Summary
- Looks like {{#get “tags”}} helper ovverides the previous context. Not able to access the partial parameters inside the {{#get}} helper
- Printing {{selected_tag}} (a partial parameter) inside the {{#get}} helper would echo its value.
Steps to Reproduce
- create a partial and send a parameter selected_tag
- Use get helper to get all tags
- Iterate with for each and check if the current tag is selected_tag with the match helper
- Printing {{selected_tag}} inside the {{#get “tags”}} helper echos empty string, but when echoing before it, it prints well.
Setup information
Ghost Version
Latest version 5.12 using Ghost(Pro)
Node.js Version
Using Ghost(Pro)
How did you install Ghost?
Using Ghost(Pro)
Using Ghost(Pro)
Database type
Using Ghost(Pro)
Browser & OS version
Not dependent on Browser or OS.
Relevant log / error output
Here is my partial tags_cloud:
<div class="tags-cloud" style="justify-content: center">
<a href="/classes/" aria-label="{{t 'All posts'}}" {{^if selected_tag}}class="active"{{/if}}>{{t 'All posts'}}</a>
<a href="#">selected: {{selected_tag}} (will print param value)</a>
{{#get "tags" limit="all" filter="visibility:public" order="name asc"}}
<a href="#">selected: {{selected_tag}} (will print empty string)</a>
{{#if tags}}
{{#foreach tags}}
<a href="{{url}}" aria-label="{{name}}" {{#match selected_tag name}}class="active"{{/match}}>{{name}}</a>
{{/foreach}}
{{/if}}
{{/get}}
</div>
<style>
.tags-cloud a.active {
background-color: var(--ghost-accent-color);
</style>
and used in 2 places like this:
{{>tags_cloud}}
and
{{>tags_cloud selected_tag=name}}
