I’m running the activitypub setup as a server on a separate service from my ghost server instances which handles the activitypub requests for all of my ghost instances. I’m running it from the github repo with a few of the testing containers removed. I’m getting the following with anything after the github tag 1.2.7 and this service does not start so the nginx service is posting no route to host
activitypub-1 | ! Corepack is about to download https://registry.npmjs.org/pnpm/-/pnpm-12.11.0.tgz
activitypub-1 | Downloading the pnpm 12.11.0 binary for linux-x64...
activitypub-1 | Update available! 12.11.0 → 12.11.2.
activitypub-1 | Changelog: https://pnpm.io/v/12.11.2
activitypub-1 | To update, run: curl -fsSL https://get.pnpm.io/install.sh | sh -
activitypub-1 | Added 12 entries to minimumReleaseAgeExclude in pnpm-workspace.yaml (set minimumReleaseAgeStrict to true to gate these updates with a prompt):
activitypub-1 | @fedify/cli@2.4.4
activitypub-1 | @fedify/fedify@2.4.4
activitypub-1 | @fedify/hono@2.4.4
activitypub-1 | @fedify/init@2.4.4
activitypub-1 | @fedify/redis@2.4.4
activitypub-1 | @fedify/relay@2.4.4
activitypub-1 | @fedify/sqlite@2.4.4
activitypub-1 | @fedify/uri-template@2.4.4
activitypub-1 | @fedify/vocab-runtime@2.4.4
activitypub-1 | @fedify/vocab-tools@2.4.4
activitypub-1 | @fedify/vocab@2.4.4
activitypub-1 | @fedify/webfinger@2.4.4
activitypub-1 | [WARN] 2 deprecated subdependencies found: node-domexception@1.0.0, tsconfck@3.1.6
activitypub-1 | Packages: -43
activitypub-1 | -------------------------------------------
activitypub-1 | Agent skills awaiting approval: @fedify/fedify, @logtape/logtape.
activitypub-1 | Run "pnpm approve" to review them.
activitypub-1 | [WARN] Issues with peer dependencies found. Run "pnpm peers check" to list them.
activitypub-1 | Error: ERR_PNPM_IGNORED_BUILDS
activitypub-1 |
activitypub-1 | × installing dependencies
activitypub-1 | ╰─▶ Ignored build scripts: protobufjs@7.6.6
activitypub-1 | help: Run "pnpm approve-builds" to pick which dependencies should be allowed
activitypub-1 | to run scripts.
activitypub-1 |
activitypub-1 | [WARN] The install that runs before scripts failed, so your node_modules may be out of sync with your lockfile. Set "verifyDepsBeforeRun: false" to skip this install.
activitypub-1 | $ concurrently "pnpm build:dev --watch" "node --inspect=0.0.0.0:9229 --watch dist/app.js"
activitypub-1 | sh: concurrently: not found
activitypub-1 | [ELIFECYCLE] Command failed with exit code 127.
activitypub-1 | ? Verifying lockfile against supply-chain policies (786 entries)...
activitypub-1 | ✓ Lockfile passes supply-chain policies (786 entries in 1.2s)
activitypub-1 | Lockfile is up to date, resolution step is skipped
activitypub-1 | Already up to date
activitypub-1 |
activitypub-1 |
im not exactly following the directions on the github readme. i made my own docker-compose based on the project’s and stripping out the testing containers, so i only have the following services in my compose file - activitypub, migrate, nginx, pubsub, and fake-gcs. i am then starting the stack with
docker compose up activitypub nginx -d --build
this has worked for me for quite a while. im not sure what im missing here, it looks like there was a change to move to pnpm at some point which i think is what im having a problem with and not sure how to fix this.
