ActivityPub self-hosted isn't quite federating
Hi, I’m trying to complete a Ghost self-hosted installation with Docker, including ActivityPub. The website is working but the ActivityPub part is having problems. @selecteh@selecteh.org can be seen from Mastodon, and I can see my own Mastodon handles from the Network UI, but…
  • If I follow @selecteh@selecteh.org from Mastodon, first my Mastodon account says “Following” but then it says “Cancel request”. From Network I keep seeing “0 followers” and I see no way to handle follow requests.
  • If I follow my Mastodon account from Ghost, I do see on Mastodon the notification “… is following you”. But Netwrok keeps showing “Following 0” so I’m not sure it is working.
  • If I post notes from Ghost, they appear in Notes but my Mastodon account can’t see them. The same happens if I publish a full post, it appears in the Notes but I can’t see it from Mastodon.
  • If I publish toots from Mastodon mentioning @selecteh@selecteh.org publicly or privately, I don’t get any notifications in Network.
docker logs ghost-activitypub-1 spits out many warnings and some errors:
  • There are plenty of WRN fedify·federation·http: 'POST' '/.ghost/activitypub/inbox/index': 401
  • Also some WRN fedify·federation·http: 'GET' '/.ghost/activitypub/inbox/index': 404
  • These come whenever I post a note: ERR activitypub: Error updating interaction counts for post with ID 12: 'post-is-internal'
I have followed the steps in the Docker installation guide, which are quite simple when it comes to the ActivityPub part. From my env file:
COMPOSE_PROFILES=activitypub
ACTIVITYPUB_TARGET=activitypub:8080
I have searched this forum and beyond for answers, unsuccessfully. Can you help me figure out what is going on, please?
Ok, we don’t know where else to look. Everything seems to be fine, unless there is a prerequisite assumed in the documentation that we are missing. Like, do we need to install an ActivityPub server or is there one included in the Ghost Docker release?
I have commented “# ACTIVITYPUB_TARGET=activitypub:8080” in the env and everything seems to work fine now… We wanted to self-host ActivityPub as well just to save some bits to Ghost’s ActivityPub infrastructure and be 100% autonomous but we have many other things to prepare for the launch.
We hope the migration of ActivityPub server is simple if one day we want to change to self-hosted. I don’t think we’ll hit the 2000 followers cap. It would be a good problem to have. :)
I’m still without Activitypub because I do not want to use a different endpoint but my own stack.
If someone was able to do it, I will appreciate the guideline.
I just want to mention that the self-hosted instance does work, at least in the latest versions of both Ghost and ActivityPub (and activitypub-migrate).
There are a few paths to handle on reverse proxies but it is all on that forum and probably in some official doc/guide as well.
Good to know, thank you very much!
About migration, just a detail – see Migration to another ActivityPub account
Have you noticed the pubsub section in the activitypub repo? I think that is the key difference between the “fully self hosted” version and the Ghost’s hosted instance.
In my case, I’ve managed to self hosted Ap, but using my custom builds and kubernetes. Currently, I’ve switched to ap.ghost.org just because I’m not a hardcore user of fedeerated contentbut I wanted to .e sure If some day I wanted to self host that feature I could do it withouit major problems
