Add advertisement paragraph at end of every post in casper
I am using Casper theme. At the end of every post, I would like to automatically insert a paragraph for advertisement purposes.
How can I do that?
Thank you.
You can change the post.hbs template and add your paragraph there, after the {{content}}:
Another possibility would be to do it with javascript via code injection.
Thanks. It works!
