We have an AMP version for the home blog page and tag pages. If you look at the post page https://www.littlelunch.de/magazin/wochenplan/ you will see in head section <link rel="amphtml" href="https://www.littlelunch.de/magazin/wochenplan/amp/">.
Does someone know how to add this tag to /home and /tag pages?
https://www.littlelunch.de/magazin/amp
https://www.littlelunch.de/magazin/tag/suppe/
https://www.littlelunch.de/magazin/tag/suppe/amp/
@DavidDarnes I will appreciate it if you have some updates. Thanks!
Hey @shystruk
You can add them in by editing the template used for them and using the block / contentFor helper. Something like the following would work:
<!-- in your default.hbs file -->
{{{block "amplink"}}}
</head>
<!-- in your template files. e.g. index.hbs, tag.hbs… -->
{{#contentFor "amplink"}}<link rel="amphtml" href="{{@site.url}}{{page_url}}amp/">{{/contentFor}}
More info on this syntax can be found here:
Hope this helps!
Thanks. It works.
Small corrections in url href="{{@site.url}}{{page_url}}amp/"
Ah thanks for catching that, I’ve updated my original post
