To start:
- What’s your URL? https://mattmadethis.blog/games/
- What version of Ghost are you using? Latest (cli 1.9.8 and ghost 2.6.2)
- What configuration? Setup using Digital Ocean Ghost 1-click (Ubuntu 16.04)
- What browser? Google Chrome
- What errors or information do you see in the console? Failed to load resource: the server responded with a status of 404 ()
- What steps could someone else take to reproduce the issue you’re having? Visit the URL linked above and inspect the page to view the console
Hi!
I am working on adding a build of a Unity game I made to a static blog post (potentially non-static ones in the future) and I am having some troubles getting it to serve up the files properly. There are some issues in Unity with this type of build so I was anticipating having some issues based on this documentation: Unity - Manual: Deploy WebGL application which covers the case of an IIS or Apache server but unfortunately doesn’t say anything about a node.js server. It looks like I need to change the mime types to allow the .unityweb extension, which I have done in the nginx server
- open ~/etc/nginx/mime.types
- add the line for the proper mime type, save and close
- restart nginx
The other thing of note in that documentation is around removing the file extension for .unityweb, and I am not sure if that is something I need to do in this case.
Note that the
<remove fileExtension=".unityweb" />lines are required to handle a situation when content type is already overridden at a higher level in the server directory’s hierarchy, which could otherwise cause a server exception.
I am wondering if there are more changes I need to make to the express server to facilitate this as well. On a previous project with a similar server architecture (nginx, express, node) I got a unity build working on a simple single page application by loading the files statically in express like:
siteApp.use(express.static(path.join(__dirname, ‘public/unity’)));
I think part of my problem is figuring out where to store my Unity files. Should I store them in the express public directory ({ghost}/current/core/server/public)? Or since I am accessing them from inside my theme should I include them in the theme assets?
Sorry for the multi-part question, this has been plaguing me for days.
Happy to provide more info as needed.
Thanks!
Matt
