Best way to automate post-publication process
Hello
After each publication, I want to trigger a process which will:
  • Move images in the right directory (publication date ‘year/month’ and not current ‘year/month’)
  • Update image links accordingly
  • Add first landscape image (or first image fallback) as feature image
Actually, I do it with a custom handmade python script, but I’m thinking about:
  • Rewrite in js the 3 steps above (need to learn the language, need some days)
  • Expose this js with ‘slug’ in input
  • Trigger a webhook when a new post has been published to request this page.
Any feedback about those steps?
Any code to help me in this quest?
If someone has the same need and want to co-develop this with me, we can share the code repo for sure. I already know (in python) how to use the admin API, and how to handle the mobiledoc part of the post.
Best
ps : another (better) way to do that is to modify the publication process in the interface, but I’m pretty sure that ghost admin will prefer that we use API to perform such “specific” action.
I think it’s an awesome idea to generalize this to actually make a “ghost sidecar” service that is supposed to be run alongside the ghost service, which can be configured to do these things (and others).
Hello again
So I wrote some lines for the last step (setup first landscape image as featured image) here.
update.js file:
const GhostAdminAPI = require('@tryghost/admin-api');
const probe = require('probe-image-size');
arguments = process.argv.slice(2)
const config = require(arguments[0])
const ghost_dir = config.paths.contentPath.replace('/content','')
const ghost_url = config.url.replace(/\/$/, "");
console.log(ghost_url)
console.log(ghost_dir)
console.log(config.scripts.admin_key)
const api = new GhostAdminAPI({
    url: ghost_url,
    key: config.scripts.admin_key,
    version: 'v3'
api.posts.browse()
  .then(response => console.log(
    '%s contains %s posts',
    config.url,
    response.meta.pagination.total));
var post_slug = arguments[1];
console.log('slugs: ', post_slug);
function get_images_from_card(card) {
  let images = [];
  switch (card[0]) {
    case 'gallery':
      card[1].images.forEach(
        element => {
          images.push(element.src)
      break;
    case 'image':
      images.push(card[1].src)
      break;
  // console.log('images : %s', images)
  return images
function isEmpty(str) {
  return (!str || str.length === 0 );
function update_post(post){
  var mdoc = JSON.parse(post.mobiledoc)
  var cards = mdoc.cards
  let images = []
  // Get all images defined in card sections
  cards.forEach(
    element => images = images.concat(get_images_from_card(element)));
  // Remove duplicates
  images = Array.from(new Set(images))
  // Rename and get featured image
  let feature_image = ''
  for(var i=0; i < images.length; i++) {
    images[i] = images[i].replace(ghost_url, ghost_dir);
    let data = require('fs').readFileSync(images[i]);
    if (isEmpty(feature_image)) {
      p_data = probe.sync(data)
      if (p_data.width > p_data.height) {
        feature_image = images[i]
      // console.log(p_data);
  // Fallback first image
    feature_image = images[0]
  post.feature_image = feature_image.replace(ghost_dir, ghost_url);
  console.log('featured : %s', post.feature_image)
  console.log('Updating post %s with %s', post.id, post.feature_image)
  api.posts.edit({id: post.id,
    updated_at: post.updated_at,
    feature_image: post.feature_image})
api.posts.read({slug: post_slug})
  .then(
    post => update_post(post)
  .catch(error => {
    console.error('Error or Post %s not found',post_slug)
    console.error(error)
I added the admin token directy in the config.development.json file:
  "scripts": {
    "admin_key": "YOUR_KEY"
And I run this code using
node update.js /path_to/config.production.json slug
This is my first javascript program. Feel free to give me feedback!
Next step: create a dedicated API endpoint with a JS code to do the other steps as well.
Ok,
It may not be perfect as it’s my first lines in javascript, but it seems to work. Here is my code:
const express = require("express")
const ProbeImageSize = require('probe-image-size');
const fs = require('fs')
const app = express()
const PORT = 3000
const ghostDir = config.paths.contentPath.replace('/content','')
const ghostUrl = config.url.replace(/\/$/, "");
console.log('Site '+ ghostUrl + ' installed in ' + ghostDir)
function checkIP(req) {
    const whitelistedIP = ['::1', '::ffff:127.0.0.1']
    if (whitelistedIP.includes(req.ip)) {
        console.log('Connection GRANTED from %s', req.ip)
        return true
    } else {
        console.log('Connection DROPPED from %s', req.ip)
        return false
// Update
    url: ghostUrl,
    version: 'v3'
    let images = [];
    switch (card[0]) {
      case 'gallery':
          element => {
        break;
      case 'image':
        break;
    return images
  function selectFeatureImage(images) {
    let featureImage = ''
    for(let i=0; i < images.length; i++) {
      images[i] = images[i].replace(ghostUrl, ghostDir);
      let data = fs.readFileSync(images[i]);
      if (isEmpty(featureImage)) {
        p_data = ProbeImageSize.sync(data)
          featureImage = images[i]
      featureImage = images[0]
    return featureImage.replace(ghostDir, ghostUrl);
  function updateImageCard(imageCard, imagesPrefix) {
    const targetDir = ghostDir + '/content/images/' + imagesPrefix
    const targetUrl = ghostUrl + '/content/images/' + imagesPrefix
    originalImageUrl = imageCard.src
    const originalImagePath = originalImageUrl.split('/')
    const imageName = originalImagePath[originalImagePath.length - 1]
    const originalImageDir = ghostDir + '/content/images/'
      + originalImagePath[originalImagePath.length - 3] + '/'
      + originalImagePath[originalImagePath.length - 2]
      + '/' + imageName
    const targetImageDir = targetDir + '/'+ imageName
    const targetImageUrl = targetUrl + '/'+ imageName
    // console.log('%s -> %s', originalImageDir, targetImageDir)
    if (targetImageUrl != originalImageUrl) {
        // Do not overwrite existing image
        if (fs.existsSync(targetImageDir) && fs.existsSync(originalImageDir)) {
          console.error('Cannot move %s to %s', originalImageDir, targetImageDir)
          console.error('Both images exists');
          return null
        } else if (!fs.existsSync(targetImageDir) && fs.existsSync(originalImageDir)) {
          // console.log('Moved %s to %s', originalImageDir, targetImageDir)
          fs.rename(originalImageDir, targetImageDir, function (err) {
            if (err) throw err
            imageCard.src = targetImageUrl
            return imageCard
          // imageCard.src = targetImageUrl
          // return imageCard
        } else if (fs.existsSync(targetImageDir) && ! fs.existsSync(originalImageDir)) {
          console.log('Updated %s to %s', originalImageDir, targetImageDir)
          return imageCard
        } else {
          console.log('Nothing to do')
          return null
  function updateCard(card, imagesPrefix) {
    switch (card[0]) {
      case 'gallery':
        images = card[1].images
          newCard = updateImageCard(images[i], imagesPrefix)
          if (newCard) {
            images[i] = newCard
        // console.log('new images', images)
        const valImages = {}
        valImages['images'] = images
        return ['gallery', valImages]
      case 'image':
        // console.log('Image card : %s', card[1])
        newCard = updateImageCard(card[1], imagesPrefix)
        if (newCard) {
          // console.log(newCard)
          return ['image', newCard]
        } else {
          return card
      default:
        return card
  function updateCards(cards, imagesPrefix) {
    newCards = []
    cards.forEach(
      card => newCards.push(updateCard(card, imagesPrefix)));
    return newCards
  function createImageDir(postDateYear, postDateMonth) {
    const yearDir = ghostDir + '/content/images/' + postDateYear
    if (!fs.existsSync(yearDir)){
      fs.mkdirSync(yearDir);
      console.log('Directory %s created', yearDir)
    const monthDir = yearDir + '/' + postDateMonth
    if (!fs.existsSync(monthDir)){
      fs.mkdirSync(monthDir);
      console.log('Directory %s created', monthDir)
  function updatePost(post){
    let mdoc = JSON.parse(post.mobiledoc)
    let cards = mdoc.cards
    let images = []
    const postDate = new Date(Date.parse(post.published_at))
    // console.log(post_date)
    const postDateMonth = ('0' + (postDate.getMonth()+1)).slice(-2)
    const postDateYear = postDate.getFullYear();
    const imagesPrefix = postDateYear + '/' + postDateMonth
    console.log('%s/%s Updating post %s', postDateMonth, postDateYear, post.slug)
    // Create image dir if needed
    oldCardsStr = JSON.stringify(cards)
    cards = updateCards(cards, imagesPrefix)
    // Get images defined in card sections
    cards.forEach(
    featureImage = selectFeatureImage(images)
    // console.log('featured : %s', featureImage)
    mdoc.cards = cards
    if (oldCardsStr != JSON.stringify(cards)) {
      console.log('Updating post %s with images and feature image to %s', post.id, featureImage)
        mobiledoc: JSON.stringify(mdoc),
        feature_image: featureImage})
    } else if (featureImage != post.feature_image) {
      console.log('Updating post %s feature image to %s', post.id, featureImage)
    } else {
      console.log('Post %s is up to date', post.id)
function updatePostReq(postSlug) {
    api.posts.read({slug: postSlug})
    .then(
      post => updatePost(post)
    .catch(error => {
      console.error('Error or Post %s not found',postSlug)
// API side
app.use(express.json());
app.get('/check', (req, res) => {
    res.end('online');
    console.log('server online')
    res.status(200).end()
app.post("/update", (req, res) => {
  if (!checkIP(req)) {
      return
  const slug = req.body.post.current.slug
  console.log('Request to update %s', req.query.slug)
  updatePostReq(slug)
app.get('/update', (req, res) => {
        return
    if (req.query.slug) {
        res.end('update post '+ req.query.slug);
        console.log('Request from %s to update %s', req.ip, req.query.slug)
        updatePostReq(req.query.slug)
app.listen(PORT, () => console.log(`🚀 Server running on port ${PORT}`))
I use pm2 to let this code running.
Create conf file:
    "apps": {
        "name": "ghost-tools-update",
        "exec": "index.js",
        "args": "/path_to/config.production.json",
        "watch": true,
        "ignore_watch": [
            "node_modules",
            "logs"
        "error_file": "/home/ghost/.pm2/logs/ghost-tools-update-err.log",
        "out_file": "/home/ghost/.pm2/logs/ghost-tools-update-out.log",
        "log_date_format": "YYYY-MM-DD HH:mm:ss"
And launch:
$ sudo -u ghost pm2 start index.js pm2.conf
and I created two webhooks to https://localhost:3000/update triggered by ‘Post published’ and ‘Published post updated’
Hope it will help somebody else to do the same thing.
I will continue to improve this code, but if somebody, better in JS than me, want to help, I can share the updates on gitlab.
