Bigger site failing on DO $5 droplet
Hello,
I have moved my site mrhack.io from WordPress to Ghost - smallest $5 Digital Ocean droplet. It has ~5K posts and just above 10k visits per month.
But, it started to fail on Ghost - I’m using UptimeRobot - and site is down few times per day, I need to do ghost restart.
In DO dashboard I can see that CPU usage and Disk I/O spike when the site is down. Probably it is because of large database.
What would you recommend apart from upgrading?
If upgrading, which droplet can solve the issue?
Thank you a lot!
Try the free version of cloudflare.
You could also try enabling more virtual memory on your droplet. The technical term is a swap file:
thank you @shodandad!
Seems the issue is solved with adding a swap file. I followed this guide:
Glad to hear it!
Why not go for the managed version from ghost.org? Ghost(Pro) - Official managed hosting for Ghost
It frees you from low level sysops stuff. It’s not that expensive and a good way to support the team and future ghost development?
That’s what I’ve done with mine. It’s very easy to setup a DO blog but I want to focus on writing articles instead of managing servers etc. Too much when I last tried it. Their prices are reasonable and I can now sleep at nights thinking on what article to post next.
@binaryanomaly @SylarRuby yeah probably managed version is the way… So far this issue seems to be solved, will see.
I am tbh thinking about it, too.
DO is good to try out but even if ghost is quite simple and easy to maintain I don’t think it’s worth my time and I rather spend 4$ more a month to make it somebody else’s problem with the positive side effect that I support development etc.
Edit: Just did it :slight_smile:
I’m self hosting mine at home using unraid and docker. Two click updates - easy peazy.
I want full control over every aspect of my data.
Cloudflare is the most essential component of all of this, and is free too!
